Making a new quadcopter with a APM 2.8 flight controller using a Ublox M8N GPS.
Mission planner upgraded me from V 1.3.45 to V 1.3.46 as I loaded the Firmware on the APM 2.8.
Prior builds (using the M8N) GPS accuracy in Loiter rock-solid. All of a sudden (after the Mission Planner 1.3.46 upgrade)… The drone flies off as soon as Loiter mode is engaged. Multiple hardware (and configuration) checks & changes, with no progress.
Then noticed in the Mission Planner 1.3.46 change log… Ulblox “driver update” ?
Reverted the Mission Planner back to V 1.3.45. Reloaded the Firmware… Problem (GPS accuracy) resolved.
The series of events (in my mind) confirm that Mission Planner 1.3.46 has a problem with the accuracy of the Ublox GPS.
Others discovered the same ???
Thanks, Jack
