Mission Planner graphing
Hi
Is there some way to plot 2x y axis in mission planner. The X axis is always the time and it is common so 2x Y axis can be plotted to show two related values with different ranges (like motor pwm values and arm state)?
by default there is just 1 Y axis and if I plot PWM (0-1000) and Arm state (0-1), the graph y axis shows the entire range and seeing the value is almost impossible.
Use a different application. MAVExplorer, UAV Log Viewew, others. This is a very useful post:
Plot Juggler
Or right click on the value that you want to display, that will put it on a different scale that is displayed on the right side of the graph. Note: You can have only two scales left and right, but can add any values to the by left and right clicking.
