Mission Planner extremely slow parameter load- isolated to specific laptop (works fine on other PCs)
Hi everyone,
I am experiencing an issue where Mission Planner takes an exceptionally long time (or hangs) during the “Getting Params” stage when connecting to a flight controller.
Crucially, this issue is strictly isolated to one laptop. When connecting the exact same flight controller and USB cable to other laptops, the full parameter list loads normally within seconds.
System Details
  • OS: Windows 10 / 11
  • Ground Station: Mission Planner (Latest Stable / Beta)
  • Connection: Direct USB Cable
Troubleshooting Already Attempted
Since the hardware and connection work on other PCs, FC/SD-card hardware issues have been ruled out. On the affected laptop, the following steps were tried without success:
  1. Mission Planner Configuration & App Data:
    • Cleared local parameter cache (parameter.cache).
    • Performed a clean uninstall and wiped %appdata% & %localappdata% MP directories.
    • Tested Mission Planner Stable, Beta, and Portable (ZIP) releases.
    • Disabled Speech/Voice options in Planner settings to rule out TTS thread hangs.
  2. Drivers & Windows Environment:
    • Reinstalled USB-to-Serial / ST VCP drivers.
    • Decreased COM Port Latency Timer to 1 ms in Device Manager.
    • Disabled USB Selective Suspend and power throttling in Windows Power Options.
    • Verified Regional Decimal Separator settings (. vs ,).
    • Added Windows Defender exclusions for the Mission Planner directory.
    • Disabled virtual network adapters/VPNs to prevent UDP loopback interception.
    • Tested direct USB 2.0/3.0 ports and unpowered hubs.
Despite these steps, parameter loading on this specific machine remains stuck or extremely slow.
Has anyone encountered this Windows/driver-level packet delay or .NET thread blocking with Mission Planner? Are there specific debug log flags I can turn on in MP to see where the MAVLink packet loop is getting stuck?
Thanks for any help!
try unplugging the laptop power supply and test running the laptop on battery, third party chargers or chargers with bad capacitors can put out really noisy dc power.
same issue with and without charger.
PS: using the original charger
Do the MissionPlanner driver clean by pressing Control F and find it 2nd down on the right hand list, then reboot
then download and install the driver package
https://firmware.ardupilot.org/Tools/MissionPlanner/driver.msi
In MissionPlanner make sure the Connect baud rate is 115200
thanks…tried this as well…did not worked…im switching back to a previous version
Try some good old fashioned Windows cleanup:
scf /SCANNOW
dism.exe /online /Cleanup-Image /StartComponentCleanup
In Device Manager, you can select to display non-present device. Look for any conflicting or strange COM ports. You can even delete them all and they’ll get reinstalled as required.
