My mission planner becoming mad automatic take off the bird what should I do?
Hello @Amir_Shehzad welcome to the comunity,
The first and most important thing that you need to do, to fix the issue is: Explain the problem in detail:
- What do you expect to happen?
- Why do you expect that to happen?
- What is really happening instead?
- Which ArduPilot vehicle type and firmware version are you using?
- Which Mission Planner version are you using?
- How can we reproduce the problem you are seeing? Describe every step.
We can not guess what is happening, unless you explain it to us.
