Hello everyone,
I am working with a Pixhawk 2.4.8, running ArduPilot (Copter), and my objective is to use the Holybro H-Flow optical flow sensor over CAN (DroneCAN) for position/velocity estimation.
The hardware is connected correctly, on the CAN bus. However, I am unable to configure EKF3 to use optical flow because several required EKF3 source parameters are missing from the parameter list.
Problem Description
According to the documentation, the following EKF3 parameters should be available to configure optical flow as a velocity source:
EK3_SRC1_POSXY = 0(None) -
EK3_SRC1_VELXY = 5(Optical Flow) -
EK3_SRC1_POSZ = 1(Barometer) -
EK3_SRC1_VELZ = 0(None) -
EK3_SRC1_YAW = 1(Compass) -
EK3_SRC_OPTIONS = 0(Disable FuseAllVelocities)
However, on my Pixhawk 2.4.8:
These
EK3_SRC*parameters do not appear at all in Mission Planner -
Because of this, I cannot select Optical Flow as a velocity source
As a result, no optical flow data is being fused into EKF
Current Setup Details
Flight Controller: Pixhawk 2.4.8
Firmware: ArduPilot Copter
Optical Flow Sensor: Holybro H-Flow (CAN / DroneCAN)
CAN parameters:
CAN_P1_DRIVER = 1 -
CAN_D1_PROTOCOL = 1(DroneCAN)
EKF is set to EKF3 (default)
what should i do?
