Missing channels on Stock Radio FS-TH9X?
Where are channel 8 and 9 on FS-TH9X ?
I wish to use one of the upper pot to control Gimbal jaw.
Can I do it ??
Thanks
Ginosergio
They are not configured in addition the receiver only has 8 channels so channel 9 will not work.
Here is a video on configuring channel 8 for a switch but should be able to do pot as well.
youtube.com/watch?v=OhLzSGItdCs
Mike
Thanks Mike !
I will try to follow that instructions, even if the video is far from clear, I do not see the buttons when he clicks them…
I hope to not mess up my TX. Maybe there is a way to COPY the whole setting of the first MODEL, as a second model, to keep a backup ??
Ginosergio
Here is how to put it back if you mess it up and maybe a clue how things work…
3drobotics.com/wp-content/upload … cedure.pdf
Mike
I used the following to activate channel 8 on my IRIS+ radio and then assigned a switch (THR - left rear) to activate Simple Mode when I get confused about orientation :laughing: :
communistech.com/how-to-conf … iris-quad/
You should be able to copy channel 6 to channel 8 and just change the pot number.
Note: operation for IRIS+ is a little different from original IRIS but I was able to figure it out with the referenced document. With the help of the previous post you should have an easier time!
