I’m not sure where to post this as it could be a 3.6 bug or a Mission Planner bug.
I’m using Mission Planner 1.3.64
F.C. is a Pixracer detected as PX4v4, running arducopter 3.6.7
Using the setup wizard, after calibrating compass and clicking OK:
Error message just as it starts to load Params: “Missing BATTERY_CAPACITY, something is wrong”.
I click OK, then it loads the other Param1 data.
In Battery Monitor, I selected 3: PX4 (also tried 4: Pixhawk ), then NONE for sensor, and 2200 for Battery size (also tried other sizes).
When I click “next”, I get an error message: “Failed to set battery size, please check your input”.
And it’s stuck there at Battery Monitor setup. I tried the wizard over and over. No good. Even restarted. Even reinstalled 3.6.7. So, I can’t move on from there to continue the rest of the setup.
Any ideas, or is this a bug? Maybe I’d have better luck installing an earlier version like 3.6.6 or 3.6.5, etc?
I am not new to Mission Planner. I first used it 4 years ago. But the computer I used for it died, so I installed a more modern version on another computer today. Also, in the past, I used Mini-APM’s, but I want to do Throw mode with a special project so I needed to get a different FC of similar size to run the more modern firmware for Throw mode.
