You should parameterize the speed parameters more correctly according to your VTOL before the next fixed-wing transition: You are flying at about 20-25 m/s in FBWA , but have overlooked to adjust AIRSPEED_CRUISE with 12 m/s much too low and below AIRSPEED_MIN (17 m/s) . More important is SCALING_SPEED, which is also too low at 15 m/s and probably triggers the rocking. You should set it to your planned cruising speed and fly an autotune with it. You should also think about which throttle setting you need to maintain the cruising speed and enter this value in TRIM_THROTTLE.
