Micoair743 flight controller
Can anyone confirm the FC runs on 2S ?
The ArduPilot documentation says 2-6S.
The Micoair manual says 3-6S.
Need someone used/tested this FC to confirm. And maybe you can ask this on discord also, to speed up the feedback.
If I understand correctly with those documents:
My guess is it will work on 2S but obviously the 9v BEC won’t work. This is the case with the Matek H743-Mini, which I ran on a 2S Li-ion.
Try it and then post about the result.
Feedback from The Almighty Taobao:
  • It supports 2S
  • @dkemxr and BEC 9V output should be (2S - 1)V
@twistedwings Hope it helps!
EDIT: Still hope MicoAir Dev can give a more detailed info.
many thanks !
I’ll give it a try and post the results…
got the flight controller.
It drops out below 4.1V.
The 9V BEC works above 10.0V, below 10.0V the output is Vbat - 1.0V.
