I’m using the Jetson TK1 and I’ve successfully started a simple mavproxy link at startup with
however, when I add the udp output
the code does not succeed at startup. This same line runs with no issues from the command line after bootup. Any thoughts? I’ve tried to sleep for up to 5 seconds in the beginning of the rc.local file without success.
