MAVLink debug-trap and safety-switch command guard issues
Reproduction environment
Vehicle: ArduCopter SITL
ArduPilot baseline: ArduPilot-4.7 branch snapshot / 4.7.0 beta-era build
Tested commit: 97775f82cec5bd50296c523be9baa0dacef9bb9e
Commit summary: Plane: version to 4.7.0-beta7
SITL command shape: build/sitl/bin/arducopter --wipe --speedup 8 --model quad --defaults Tools/autotest/default_params/copter.parm
MAVLink: MAVLink 2, ardupilotmega dialect
Safety/authority guard bypasses
1. MAV_CMD_DEBUG_TRAP: debug trap can terminate the autopilot process even when addressed to another component
Input tested
COMMAND_LONG command=42700 MAV_CMD_DEBUG_TRAP target_component=42 params=[32451,0,0,0,0,0,0].
Reproduction steps
  1. Start a fresh ArduCopter SITL instance.
  2. Send MAV_CMD_DEBUG_TRAP with the magic value 32451 to target_component=42.
  3. Observe command ACK behavior and process liveness.
Observed behavior
  • The client did not receive a normal command ACK.
  • The MAVLink connection was lost immediately after sending the command.
  • The client log records sitl_exit_code=-5.
Expected behavior
A debug trap should not be reachable in normal operation, and it should not affect the autopilot when addressed to a different component.
Impact
A MAVLink sender can terminate the running autopilot process in SITL by sending the magic debug-trap command.
Code evidence
  • libraries/GCS_MAVLink/GCS_Common.cpp:5119-5128: The handler checks only the magic value and then calls hal.util->trap().
5119: MAV_RESULT GCS_MAVLINK::handle_command_debug_trap(const mavlink_command_int_t &packet)
5120: {
5121:     // magic number must be supplied to trap; you must *really* mean it.
5122:     if (uint32_t(packet.param1) != 32451) {
5123:         return MAV_RESULT_DENIED;
5124:     }
5125:     if (hal.util->trap()) {
5126:         return MAV_RESULT_ACCEPTED;
5127:     }
5128:     return MAV_RESULT_UNSUPPORTED;
  • libraries/GCS_MAVLink/GCS_Common.cpp:5675-5676: MAV_CMD_DEBUG_TRAP dispatches to this handler.
5675:     case MAV_CMD_DEBUG_TRAP:
5676:         return handle_command_debug_trap(packet);
2. MAV_CMD_DO_SET_MODE: legacy safety base-mode path accepts remote safety-switch changes
Input tested
COMMAND_LONG command=176 MAV_CMD_DO_SET_MODE params=[128,0,0,0,0,0,0] and params=[128,1,0,0,0,0,0], where 128 is MAV_MODE_FLAG_DECODE_POSITION_SAFETY.
Reproduction steps
  2. Send MAV_CMD_DO_SET_MODE with base mode MAV_MODE_FLAG_DECODE_POSITION_SAFETY and custom mode 1 to force safety on.
  3. Send MAV_CMD_DO_MOTOR_TEST with direct PWM input as a behavior check.
  4. Send MAV_CMD_DO_SET_MODE with the same base mode and custom mode 0 to force safety off.
  5. Send the same motor-test command again.
  6. Send MAV_CMD_DO_SET_MODE with custom mode 1 again and repeat the motor-test command.
Observed behavior
  • The initial safety-on command returned MAV_RESULT_ACCEPTED, and the following motor-test command returned MAV_RESULT_FAILED.
  • After the safety-off command returned MAV_RESULT_ACCEPTED, the same motor-test command returned MAV_RESULT_ACCEPTED.
  • After forcing safety on again, the same motor-test command returned MAV_RESULT_FAILED again.
  • This confirms that the command path did not only acknowledge receipt; in SITL it changed the HAL safety state enough to alter a safety-gated behavior.
Expected behavior
Remote mode-setting should not expose hardware safety-switch operations without explicit authorization and guard checks.
Impact
A MAVLink mode command can exercise the safety-switch path remotely. In SITL, this changes the safety state used by motor-test gating. On hardware with safety-switch support, the same code path maps to force_safety_on() and force_safety_off(), which are primary motor-output safety operations.
Code evidence
  • libraries/GCS_MAVLink/GCS_Common.cpp:5092-5097: handle_command_do_set_mode() casts command parameters and calls _set_mode_common().
5092: MAV_RESULT GCS_MAVLINK::handle_command_do_set_mode(const mavlink_command_int_t &packet)
5093: {
5094:     const uint8_t _base_mode = (uint8_t)packet.param1;
5095:     const uint32_t _custom_mode = (uint32_t)packet.param2;
5096:
5097:     return _set_mode_common(_base_mode, _custom_mode);
  • libraries/GCS_MAVLink/GCS_Common.cpp:2892-2922: _set_mode_common() accepts MAV_MODE_FLAG_DECODE_POSITION_SAFETY and calls force_safety_off() or force_safety_on().
2892: MAV_RESULT GCS_MAVLINK::_set_mode_common(const uint8_t _base_mode, const uint32_t _custom_mode)
2893: {
2894:     // only accept custom modes because there is no easy mapping from Mavlink flight modes to AC flight modes
2895: #if AP_VEHICLE_ENABLED
2896:     if ((_base_mode & MAV_MODE_FLAG_CUSTOM_MODE_ENABLED) != 0) {
2897:         if (!AP::vehicle()->set_mode(_custom_mode, ModeReason::GCS_COMMAND)) {
2898:             // often we should be returning DENIED rather than FAILED
2899:             // here.  Perhaps a "has_mode" callback on AP_::vehicle()
2900:             // would do?
2901:             return MAV_RESULT_FAILED;
2902:         }
2903:         return MAV_RESULT_ACCEPTED;
2904:     }
2905: #endif
2906:
2907:     if (_base_mode == MAV_MODE_FLAG_DECODE_POSITION_SAFETY) {
2908:         // set the safety switch position. Must be in a command by itself
2909:         if (_custom_mode == 0) {
2910:             // turn safety off (pwm outputs flow to the motors)
2911:             hal.rcout->force_safety_off();
2912:             return MAV_RESULT_ACCEPTED;
2913:         }
2914:         if (_custom_mode == 1) {
2915:             // turn safety on (no pwm outputs to the motors)
2916:             if (hal.rcout->force_safety_on()) {
2917:                 return MAV_RESULT_ACCEPTED;
2918:             }
2919:             return MAV_RESULT_FAILED;
2920:         }
2921:         return MAV_RESULT_DENIED;
2922:     }
  • libraries/GCS_MAVLink/GCS_Common.cpp:5717-5718: MAV_CMD_DO_SET_MODE dispatches to this handler.
5717:     case MAV_CMD_DO_SET_MODE:
5718:         return handle_command_do_set_mode(packet);
  • libraries/AP_HAL_SITL/RCOutput.h:22-39: In SITL, force_safety_on() and force_safety_off() update the stored safety state.
22:     /*
23:       force the safety switch on, disabling PWM output from the IO board
24:      */
25:     bool force_safety_on(void) override {
26:         safety_state = AP_HAL::Util::SAFETY_DISARMED;
27:         return true;
28:     }
29:     /*
30:       force the safety switch off, enabling PWM output from the IO board
31:      */
32:     void force_safety_off(void) override {
33:         safety_state = AP_HAL::Util::SAFETY_ARMED;
34:     }
35:
36:     /*
37:       get safety switch state, used by Util.cpp
38:     */
39:     AP_HAL::Util::safety_state _safety_switch_state(void) { return safety_state; }
  • libraries/AP_HAL_SITL/Util.cpp:89-97: The SITL utility safety-state query returns the RCOutput safety state.
89: enum AP_HAL::Util::safety_state HALSITL::Util::safety_switch_state(void)
90: {
91: #define HAL_USE_PWM 1
92: #if HAL_USE_PWM
93:     return ((RCOutput *)hal.rcout)->_safety_switch_state();
94: #else
95:     return SAFETY_NONE;
96: #endif
97: }
  • ArduCopter/GCS_MAVLink_Copter.cpp:734-747: MAV_CMD_DO_MOTOR_TEST dispatches to mavlink_motor_test_start().
734: MAV_RESULT GCS_MAVLINK_Copter::handle_MAV_CMD_DO_MOTOR_TEST(const mavlink_command_int_t &packet)
735: {
736:         // param1 : motor sequence number (a number from 1 to max number of motors on the vehicle)
737:         // param2 : throttle type (0=throttle percentage, 1=PWM, 2=pilot throttle channel pass-through. See MOTOR_TEST_THROTTLE_TYPE enum)
738:         // param3 : throttle (range depends upon param2)
739:         // param4 : timeout (in seconds)
740:         // param5 : num_motors (in sequence)
741:         // param6 : motor test order
742:         return copter.mavlink_motor_test_start(*this,
743:                                                (uint8_t)packet.param1,
744:                                                (uint8_t)packet.param2,
745:                                                packet.param3,
746:                                                packet.param4,
747:                                                (uint8_t)packet.x);
  • ArduCopter/motor_test.cpp:127-131: Motor test is rejected when hal.util->safety_switch_state() reports SAFETY_DISARMED.
127:     // check if safety switch has been pushed
128:     if (hal.util->safety_switch_state() == AP_HAL::Util::SAFETY_DISARMED) {
129:         gcs_chan.send_text(MAV_SEVERITY_CRITICAL,"%s: Safety switch", mode);
130:         return false;
131:     }
  • ArduCopter/motor_test.cpp:143-161: If the safety checks pass, motor test returns success and emits the normal start path.
143: // mavlink_motor_test_start - start motor test - spin a single motor at a specified pwm
144: //  returns MAV_RESULT_ACCEPTED on success, MAV_RESULT_FAILED on failure
145: MAV_RESULT Copter::mavlink_motor_test_start(const GCS_MAVLINK &gcs_chan, uint8_t motor_seq, uint8_t throttle_type, float throttle_value,
146:                                          float timeout_sec, uint8_t motor_count)
147: {
148:     if (motor_count == 0) {
149:         motor_count = 1;
150:     }
151:     // if test has not started try to start it
152:     if (!ap.motor_test) {
153:         /* perform checks that it is ok to start test
154:            The RC calibrated check can be skipped if direct pwm is
155:            supplied
156:         */
157:         if (!mavlink_motor_control_check(gcs_chan, throttle_type != 1, "Motor Test")) {
158:             return MAV_RESULT_FAILED;
159:         } else {
160:             // start test
161:             gcs().send_text(MAV_SEVERITY_INFO, "starting motor test");
Suggested fixes
  • Gate debug/trap commands behind an explicit debug build or runtime option and strict target checks.
  • Avoid exposing safety-switch operations through legacy mode fields unless an explicit authorization path is used.
  • Return failure when a safety-affecting command is unavailable, not permitted, or not addressed to the autopilot component.
I’m not going to waste my time on any more of this type of thing. You are welcome to make PRs to fix issues yourself, but I suggest you use a concise, well explained narrative rather than this lengthy, auto-generated format.
Continuing in this vein may result in restrictions being placed on your account, as it is not particularly helpful here.
