I’m unsure whether this is a bug or if it’s an issue on my code, so I’d like to get confirmation from experts here.
Thank you in advance.
I’ve uploaded my “ReadArduRoverModeSimple” code below:
[Code]
/* ~inluded for receiving serial char~ */
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <unistd.h>
#include <stdint.h>
#include <fcntl.h>
#include <termios.h>
#include <errno.h>
#include <sys/ioctl.h>
#include "../include/mavlink/ardupilotmega/mavlink.h"
#include <iostream> //include for std::cout
std::string arduRoverModeNumberToString(uint32_t custom_mode)
switch(custom_mode)
case 0 : return "MANUAL";
case 1 : return "ACRO";
case 3 : return "STEERING";
case 4 : return "HOLD";
case 5 : return "LOITER";
case 6 : return "FOLLOW";
case 7 : return "SIMPLE";
case 10 : return "AUTO";
case 11 : return "RTL";
case 12 : return "SMART_RTL";
case 15 : return "GUIDED";
case 16 : return "INITIALIZING";
default : return "UNKNOWN";
int main(int argc, char *argv[])
int file_descriptor;
struct termios toptions;
//file_descriptor = open("/dev/ttyUSB0" , O_RDWR | O_NOCTTY | O_NDELAY); <- have error. but official "uart-c" example code use this setup
file_descriptor = open("/dev/ttyUSB0" , O_RDWR | O_NOCTTY);
std::cout << "file descriptor opened as int : " << file_descriptor << std::endl;
tcgetattr(file_descriptor, &toptions);
cfsetispeed(&toptions, B57600);
cfsetospeed(&toptions, B57600);
/* 8 bits, no parity, no stop bits */
toptions.c_cflag &= ~(CSIZE | PARENB);
toptions.c_cflag |= CS8;
//Mavlink official "uart-c" example code use this input flag.
toptions.c_iflag &= ~(IGNBRK | BRKINT | ICRNL | INLCR | PARMRK | INPCK | ISTRIP | IXON);
//Mavlink official "uart-c" example code use this local flag.
toptions.c_lflag &= ~(ECHO | ECHONL | ICANON | IEXTEN | ISIG);
toptions.c_cc[VTIME] = 1;
toptions.c_cc[VMIN] = 10;
/* commit the serial port settings */
tcsetattr(file_descriptor, TCSANOW, &toptions);
//tcsetattr(file_descriptor, TCSAFLUSH, &toptions);
mavlink_status_t status;
mavlink_message_t msg;
int chan = MAVLINK_COMM_0;
uint8_t mavlink_byte;
int last_msg_sequence = 0;
int lost_message_number = 0;
while(true) {
//read(int fd, void *buf, size_t count);
int number = read(file_descriptor, &mavlink_byte, 1);
if(number > 0)
if(mavlink_parse_char(chan, mavlink_byte, &msg, &status))
if(msg.msgid == MAVLINK_MSG_ID_HEARTBEAT)
mavlink_heartbeat_t heartbeat;
mavlink_msg_heartbeat_decode(&msg, &heartbeat);
std::cout << "ArduRover Mode : " << arduRoverModeNumberToString(heartbeat.custom_mode) << std::endl;
//Counting lost-message algorithm
if(last_msg_sequence > msg.seq)
std::cout << "Lost Message Number : " << lost_message_number << std::endl;
std::cout << "Lost Percentage : " << (float)((float)lost_message_number / 255) * 100 << std::endl;
lost_message_number += (msg.seq);
else if((msg.seq - last_msg_sequence) != 1)
lost_message_number += (msg.seq - last_msg_sequence - 1);
last_msg_sequence = msg.seq;
else if(number < 1) {
std::cout << "Serial Getting Failed." << std::endl;
break;
else //number = 0
std::cout << "no serial data" << std::endl;
}//end of while(true)
close(file_descriptor);
return 0;
}//end of main()
The expected result should be a continuous “GUIDED” output when I switch the transmitter to “GUIDED.”
Below is the terminal output when I connect the Jetson TK1 and Pixhawk:
[Terminal Result 1]
file descriptor opened as int : 3
ArduRover Mode : HOLD
ArduRover Mode : MANUAL
Lost Message Number : -526
Lost Percentage : -206.275
ArduRover Mode : GUIDED
Lost Message Number : 0
Lost Percentage : 0
Lost Percentage : 0
As you can see above, the lost message count is zero, and the “GUIDED” mode is correctly reported.
However, when connecting a SiK Radio telemetry module and running Windows Mission Planner simultaneously on a Windows laptop(independently with Jetson TK1), I get the following result on the console:
[Terminal Result 2(Failed)]
Lost Message Number : -16
Lost Percentage : -6.27451
Lost Message Number : 247
Lost Percentage : 96.8627
Lost Message Number : 22
Lost Percentage : 8.62745
Lost Message Number : 44
Lost Percentage : 17.2549
Lost Message Number : 95
Lost Percentage : 37.2549
Lost Message Number : 147
Lost Percentage : 57.6471
Lost Message Number : 199
Lost Percentage : 78.0392
Lost Message Number : 253
Lost Percentage : 99.2157
Lost Message Number : 36
Lost Percentage : 14.1176
Lost Message Number : 56
Lost Percentage : 21.9608
Lost Message Number : 51
Lost Percentage : 20
Lost Message Number : 102
Lost Percentage : 40
Lost Message Number : 154
Lost Percentage : 60.3922
Lost Message Number : 206
Lost Percentage : 80.7843
Lost Message Number : 73
Lost Percentage : 28.6275
Lost Percentage : 9.80392
Lost Message Number : 55
Lost Percentage : 21.5686
There are sudden message losses, and the mode switches between “GUIDED” and “MANUAL” even though I haven’t touched the transmitter. Meanwhile, Mission Planner still shows the flight mode as “GUIDED” continuosly.
As a beginner with MAVLink and Linux boards, I can’t figure out why this is happening. If anyone has insights into this issue, I would greatly appreciate any suggestions or explanations.
I think connecting the radio telemetry module in addition to the FT232 module to the Pixhawk does not affect the telemetry output on the FT232 module, but it seems to have some impact. Aren’t the two telemetry ports independent? Could this issue be related to the Pixhawk code or hardware, or should I modify my code to address potential problems?
[My Environment]
- Software: Latest ArduRover (2024.08)
- Hardware: Jetson TK1 board (OS: Linux 4 Tegra 21.8, Jetpack 3.1), Quite old
- Connection: ArduRovers’s Pixhawk 1 connected to Jetson TK1 via FT232, and connected to windows laptop with SiK Radio Telemetry.
