Now when I run MavExplorer, it starts, I can use the GUI to open up a log file. The map feature works. But it will not graph anything. It doesn’t matter if I use the GUI for a saved graph, or command line. I get the following (The first errors are from a GUI based graph) :
allister@macbook:~$ MAVExplorer.py
/home/allister/venv-ardupilot/bin/MAVExplorer.py:38: DeprecationWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html
import pkg_resources
MAV> 19:46:55: Debug: window wxMenuBar@0x2cda26c0 ("menubar") lost focus even though it didn't have it
ERROR in command [':0']:
19:47:10: Debug: window wxMenuBar@0x2d0f6dd0 ("menubar") lost focus even though it didn't have it
19:47:12: Debug: window wxTextCtrl@0x2cda7930 ("text") lost focus even though it didn't have it
MAV> graph ATT.DesRoll ATT.Roll ATT.DesPitch ATT.Pitch
MAV> ERROR in command ['ATT.DesRoll', 'ATT.Roll', 'ATT.DesPitch', 'ATT.Pitch']:
MAV>
I went back and re-ran the ubuntu dev environment scripts, but that didn’t help. Anyone have a suggestion? Thanks.
Nope. It’s an old macbook, so I keep everything pretty default not to max it out any more than it already is. I am running a second monitor. Have been for ages on this setup.
Just asking because I had it before that after an upgrade the support for custom screen resolution suddenly stopped working. (Can’t remember what the application was, which was impacted).
No difference when unplugging external screen?
Anyway, I guess you are on Wayland whilst I am still on X11.
I’ve been running it just fine under Wayland for quite some time. Not sure if it asks for the underlying xwayland support or not, but I do have that installed.
I’ve re-run the Dev script and now when I try to graph something I get:
MAV> graph GPS.Alt
MAV> Process Process-3:
Traceback (most recent call last):
File "/usr/lib/python3.12/multiprocessing/process.py", line 314, in _bootstrap
self.run()
File "/usr/lib/python3.12/multiprocessing/process.py", line 108, in run
self._target(*self._args, **self._kwargs)
File "/home/allister/venv-ardupilot/lib/python3.12/site-packages/MAVProxy/modules/lib/grapher.py", line 774, in show
self.plotit(self.x, self.y, lab, colors=col, title=self.title, interactive=interactive)
File "/home/allister/venv-ardupilot/lib/python3.12/site-packages/MAVProxy/modules/lib/grapher.py", line 439, in plotit
new_lines = ax.plot_date(x[i], y[i], fmt=color, label=fields[i],
AttributeError: 'Axes' object has no attribute 'plot_date'
Thanks to some fumbling about with an LLM, it seems that it was an issue with Matplotlib. I was on 3.11, so reverting to 3.10.9 has Mavexplorer graphing again.
