MAV_CMD_DO_SET_HOME will set the altitude to 0m
Hello.
I tried using MAV_CMD_DO_SET_HOME to set a landing point in the middle of a flight route, but when I put RTL after the MAV_CMD_DO_SET_HOME command, the altitude of the aircraft is reset to 0m, is this a bug?
If you know how to set multiple landing points on a flight route, I would appreciate it if you could let me know.
Thank you in advance.
Which GCS? Which ArduCopter firmware version?
What were the exact parameters that you sent the command with?
Hello.
Sorry for the delay.
GCS is QGroundControl.
The firmware is Copter-4.3.7.
If I use the “specified location” under “set takeoff location,” it changes the takeoff point, but resets the flight altitude to 0 m.
Hello.
I checked the flight plan created in QGroundControl with the MissionPlanner simulator.
As a result, I confirmed that the altitude is 0m after passing the “set takeoff location” command.
I would appreciate it if you could let me know if this is a bug or a specification.
The flight plan is attached.
Best regards.
20241121 Takeoff point change.zip (792 Bytes)
