Built a 3in cineboy with the matek.
The 1st imu has significantly higher vibrations than the 2 one. Should I default the controller to use the 2nd one first?
The first one is under 20 but the 2nd one is under 10 mostly under 8.
Or is it better to leave it there to allow the controller to switch if needed?
