Matek F405-TE - "Too many backends" & Compass not detected (QMC5883L)
Hi everyone,
First of all, am I right in General or should I post in another category?
I’m having trouble with my Matek F405-TE FC. I’m using ArduDeck.
The FC hangs on startup with the critical error: CRIT Config Error: Too many backends.
This issue started after I flashed a new firmware to try and fix a compass detection problem. Before this, the GPS unit (HGLRC M100-5883, linked below) was working correctly for GPS positioning, but the integrated compass was never detected by ArduPilot (neither in ArduPlane 4.7.2/4.7.0 nor ArduCopter 4.7.0).
Hardware Setup:
  • FC: Matek F405-TE
  • GPS/Compass: HGLRC M100-5883 (M10 GPS + QMC5883L Compass) Link
  • Wiring:
    • GPS Data: TX4/RX4 on FC.
    • Compass I2C: SCL to FC SCL, SDA to FC SDA.
Steps Taken:
  1. Tried to flash VTOL (ArduPlane) 4.7.2 and ArduCopter 4.7.0. ArduDeck reports “Flash successful”.
  2. Tried flashing with and without an SD card inserted.
  3. Attempted to enter Bootloader mode by holding the Boot button while powering on, ArduDeck doesn’t recognice a board, the red LED is on and the blue is slightly on.
  4. I already heard often about problems with the compass, so probably not my bad?
Hope I didn’t forget important logs etc.
Thank you for any help in advance!
LOG_BACKEND_TYPE set wrong I would guess.
Never heard of a Wing version of that board. WTE?
Thanks, I think I’ve changed the logging parameters because of arming failures. So that sounds like a good explanation…
Sorry for the Wing, obviously it isn’t. I got confused with the Speedybee F405 Wing…
To the LOG_BACKEND_TYPE: How can I change the parameter if the FC always freezes? Is there a way to hard reset? Looks like uploading firmware with the checkbox “Complete Chip erase” didn’t help.
Thank you for the help, I’m new with FCs and need to learn a lot of things… Looking forward to solve the problems!
Download the .apj file from Here for Plane
Use Mission Planner for now and from the Install Firmware Screen use Load Custom Firmware and select that downloaded file. Stay in Mission Planner and go to the Full Parameter Screen and set log_backend_type,1 and restart the board.
