I am new to arducopter, I have a nicely flying DIY-Quadcopter which I just recently pimped with a few LEDs. They are very bright, so I would like to dim them a bit using PWM. I just didnt find any way to do this in the mission planner or elsewhere, so I think I have to program this manually in the user hookup functions.
I have done a lot of µC programming, so C++ is not a problem for me. Still I dont know the Arducopter program structure very well yet.
I tried the following code in the User Hook (after enableing the userhook in the config file)
Just program the PWM yourself. See the Atmel reference manual for the ATmega1280/2560. Since you have uController experience, this should be no problem! here is some sample code:
void StopPWM(void)
TCCR2A=0;
void StartPWM(void)
// Use internal clock (datasheet p.160)
ASSR &= ~(_BV(EXCLK) | _BV(AS2));
//fixed on pin 11 and 12
//pinMode(12,OUTPUT);
// pinMode(speakerPin, OUTPUT); //OC1A
TCCR1A = _BV(COM1A0) | _BV(COM1B0) |_BV(WGM11)| _BV(WGM10);
TCCR1B = _BV(WGM13) | _BV(CS11); // /8 // no prescaling ( div by 1 )
// Set initial pulse width to the first sample.
OCR1A = 1000;
However, since you are into the code, you might try just a simple on off of the port bit and a software timer using the 100hz loop in ArduCopter. It wouldn’t be PWM, but it would still dim the LED.
Good luck!
[quote=“tbrkfd1”]Just program the PWM yourself. See the Atmel reference manual for the ATmega1280/2560. Since you have uController experience, this should be no problem! here is some sample code:
void StopPWM(void)
TCCR2A=0;
void StartPWM(void)
OCR1A = 1000;
Good luck![/quote]
Hi tbrkfd1,
thanks for your reply. Did you use this code on an arducopter? I actually thought about doing it myself manually, but I am not sure which timers are used by the rest of the software already, and I dont want to corrupt the normal stuff. Also I never found a schematic of my board (Crius AIO), so I am not 100% sure about the pin configs. This is why I thought using the ARM PWM functions should make it much easier, because the board can handle 8 Motors -> 8 PWM outputs, of which 4 of them are not used.
in addition, you have to modify the RCOutput file and there specificly the write-function to remove the period-constrain for the PWM output channel (we want PWM to start from 0%) :
[code][code]void MPNGRCOutput::write(uint8_t ch, uint16_t period_us) {
/* constrain, then scale from 1us resolution (input units)
