Hi.
Ive set RC6 to 209. Set Q_FWD_MANTHR_MAX to 70
The FWD thrust motor is working ok in manual mode. RC6 is showing normal movement.
Q_VFWD_GAIN is at zero but I understand it is no longer used?
Q_FWD_THR_GAIN is at 3.
Also I was expecting the FWD motor to assist with position holding when the nose-down exceeds a set amount. This also is not happening.
So after changing Q_VFWD_ALT to just 1m I am now getting the thrust motor assisting with position holding in the hover, however the RC6 (209) channel is still doing nothing.
Any advice please?
i am also facing such problem, i thought this setting will force the foward moters working even in Qstable mode right? btw what kind of button should i assign to? slider?
