It is interesting, with update 4.16 I have needed to set the RC channel to 208 to enable manual control of the flaps. Until now, the RC has been set to 0. Both my aircraft have had the same symptoms and the correction worked on both.
Well, I know this is an older thread, but I wanted to add some info. I’m on Arduplane 4.2.2 Official and have been scratching my head for two days trying to get the flaps to work. Here’s what I finally had to do:
Hello Brad,
Go to “user Param” and set your incoming flap channel from TX eg: if flap switch set on channel 7 then in user param rc channel 7 set to Flap from drop down list.
Make sure you have also set your flaps under servooutput.
I never understand why we have to config flaps at two location in Ardupilot, perhaps developer will answer this or may be bcoz flaps works on switch logical connection. May be or not.
Anyway,
Above settings will let your flap works. That’s how I am using it on my FX79 wing.
Remember, you are installing an autopilot, not an RC receiver. It can handle automatic flap settings. You have to tell it you’d rather control them manually, hence the configuration scheme.
