MAG interference
There seems to be MAG interference. How can I improve it?
Attach Log
https://drive.google.com/file/d/1is07qiko90tv0W-1FWgyTMIOT73bPPhq/view?usp=sharing
I would recommend disabling the internal compasses (only use external). Also mount the external compass higher up (away from electronics) if possible.
Is it only necessary to check “Compass2” to disable the internal compass on the setting screen?
Does external compass mean GPS?
I flew using only an external compass.
Next time, I will raise the GPS mount and fly.
here is some more general information which might be helpful:
Thank you for the information.
Interfering with the power version from the ESC caused interference with the compass.
