Mag Error
hi!, I am analyzing the logs of my last flight, following the tutorial:
copter.ardupilot.com/wiki/common … sing-logs/
First, I see the MAG1 and MAG2 not go together
Second, when the plane accelerates influences the MAG (I guess for magnetic fields)
I wonder, how to make MAG1 and MAG2 go hand in hand, as for now, disabling MAG2 is the only solution I’ve found.
Isn’t Mag2 attached to the GPS module. I would think that one would be less influenced by magnet interference. The other one is mounted on the Pixhawk.
I just looked at mine from a test flight and they are dead on for both throughout the flight.
Mike
There’s a reason that after APM2.5 the MAG was moved off the main controller board. It is best to ALWAYS user the external MAG and try and put it in a place away from any other electromagnetic interference and always do a calibration. The onboard MAG is subject to all sorts of interference.
Thanks, Grant.
