Lua script fail
I am trying to run a simple script on my Cube Black with the 4.4.0 dev firmware and I obtain this message always I reboot the autopilot:
Scripting: failed to start
I tried with the last stable firmware version as well and I obtain the same fail message. The script is the Hello world example Lua script.
The scr parameter is enabled and the amout of memory set is 100000, enought for this script.
Any help on that issue?
on a CubeBlack it is quite challenging to get enough memory for lua scripts. Do you have the option of changing to a CubeOrange?
