Lua gcs:send named float 20 values limit
Hello, I’m trying to send 30 named value float @t 0,5hz with the lua command gcs:named_value_float().
I only get 20 values to mission planner.
I created this topic in discuss mission planner:
Gcs:send_named_float: 20 values limitation in mission planner - Ground Control Software / Mission Planner - ArduPilot Discourse
I also asked many month ago this:
Mission planner limits number of custom fields to 20? - Ground Control Software / Mission Planner - ArduPilot Discourse
nobody replyed…
I hope you can unlock this feature.
This is hard coded. Named_float is supposed to used for testing and debugging.
You can develop your own plugin to handle extra messages or use DATA64, DATA96 messages to send a larger amount of data at once, but you also need a plugin to process them.
Thank you Andreas.
Where is hard coded? Mission planner? Or ardupilot?
Can you help me to send data64 with lua ?
There is also named int but I don’t found lua biding for it…
