Low RTF in gazebo harmonic simulation
I am trying to create a simulation world that includes two Mini Talon models, each equipped with a camera. The world is based on the standard runway world provided in the Gazebo examples.
When the simulation is running with charging enabled, I observe approximately 40% RTF. However, when charging is disabled, the RTF drops to around 7%, which is extremely low. At this point, I can no longer increase the max_step_size without introducing significant jitter in the simulation.
I am wondering whether it is possible to run this world with higher RTF values, or if there are specific optimizations I am missing. The full world file is attached below.
<?xml version="1.0" ?>
<sdf version="1.7"
    xmlns:experimental="http://sdformat.org/schemas/experimental">
  <world name="runway">
    <physics name="1ms" type="ode">
      <max_step_size>0.002</max_step_size>
      <real_time_factor>1</real_time_factor>
    </physics>
    <plugin filename="gz-sim-physics-system"
      name="gz::sim::systems::Physics">
    </plugin>
    <plugin filename="gz-sim-sensors-system" name="gz::sim::systems::Sensors">
      <render_engine>ogre2</render_engine>
    </plugin>
    <plugin filename="gz-sim-user-commands-system"
      name="gz::sim::systems::UserCommands">
    </plugin>
    <plugin filename="gz-sim-scene-broadcaster-system"
      name="gz::sim::systems::SceneBroadcaster">
    </plugin>
    <plugin filename="gz-sim-imu-system"
      name="gz::sim::systems::Imu">
    </plugin>
    <plugin filename="gz-sim-navsat-system"
      name="gz::sim::systems::NavSat">
    </plugin>
    <scene>
      <ambient>1.0 1.0 1.0</ambient>
      <background>0.8 0.8 0.8</background>
      <sky></sky>
    </scene>
    <spherical_coordinates>
      <latitude_deg>-35.363262</latitude_deg>
      <longitude_deg>149.165237</longitude_deg>
      <elevation>584</elevation>
      <heading_deg>0</heading_deg>
      <surface_model>EARTH_WGS84</surface_model>
    </spherical_coordinates>
    <light type="directional" name="sun">
      <cast_shadows>0</cast_shadows>
      <pose>0 0 10 0 0 0</pose>
      <diffuse>0.8 0.8 0.8 1</diffuse>
      <specular>0.8 0.8 0.8 1</specular>
      <attenuation>
        <range>1000</range>
        <constant>0.9</constant>
        <linear>0.01</linear>
        <quadratic>0.001</quadratic>
      </attenuation>
      <direction>-0.5 0.1 -0.9</direction>
    </light>
    <!-- ENU axes -->
    <model name="axes">
      <static>1</static>
      <link name="link">
        <visual name="r">
          <pose>5 0 0.1 0 0 0</pose>
          <geometry>
            <box>
              <size>10 0.01 0.01</size>
            </box>
          </geometry>
          <material>
            <ambient>1 0 0 1</ambient>
            <diffuse>1 0 0 1</diffuse>
            <emissive>1 0 0 1</emissive>
            <specular>0.5 0.5 0.5 1</specular>
          </material>
        </visual>
        <visual name="g">
          <pose>0 5 0.1 0 0 0</pose>
          <geometry>
            <box>
              <size>0.01 10 0.01</size>
            </box>
          </geometry>
          <material>
            <ambient>0 1 0 1</ambient>
            <diffuse>0 1 0 1</diffuse>
            <emissive>0 1 0 1</emissive>
          </material>
        </visual>
        <visual name="b">
          <pose>0 0 5.1 0 0 0</pose>
          <geometry>
            <box>
              <size>0.01 0.01 10</size>
            </box>
          </geometry>
          <material>
            <ambient>0 0 1 1</ambient>
            <diffuse>0 0 1 1</diffuse>
            <emissive>0 0 1 1</emissive>
          </material>
        </visual>
      </link>
    </model>
    <include>
      <uri>model://runway</uri>
    </include>
    <include>
      <pose degrees="true">0 0 0.2 0 0 90</pose>
      <uri>model://mini_talon_vtail</uri>
      <name>vtail_1</name>
      <experimental:params>
        <plugin element_id="camera_link::camera::GstCameraPlugin" action="modify">
            <udp_port>5600</udp_port>
        </plugin>
        <plugin element_id="ArduPilotPlugin" action="modify">
            <fdm_port_in>9002</fdm_port_in>
        </plugin>
      </experimental:params>
    </include>
    <include>
      <pose degrees="true">-2 0 0.2 0 0 90</pose>
      <name>vtail_2</name>
            <udp_port>5610</udp_port>
        </plugin>
            <fdm_port_in>9012</fdm_port_in>
        </plugin>
    </include>
    <!-- <include>
      <pose degrees="true">2 0 0.2 0 0 90</pose>
      <name>vtail_3</name>
        </plugin>
            <fdm_port_in>9022</fdm_port_in>
        </plugin>
    </include> -->
  </world>
</sdf>
Additionally, the low RTF issue persists regardless of whether the cameras are enabled or disabled; closing the camera streams does not improve performance.
I am using gazebo harmonic on Windows 11 with wsl2.
Thank you in advance for any guidance or suggestions.
