Logging failed F405
when I want to arm my Plane it always has following errors:
CRT Arm: Logging failed
CRT Bad Logging
CRT Pre Arm: Logging Failed
this is my first Arduplane Build, its an Easystar with an MATEK F405-WTE FC. I’m using the onboard ELRS receiver.
I’ve swapped SD-Cards, reformatet them(Fat32 Master Boot Record). It still has that errors. This is whats in the APM folder when I take the SD card out and put it into my Computer, and the Parameters.
What can I do?
STRG_BAK.zip (10.7 KB)
Parameters.params.zip (6.8 KB)
Try LOG_BACKEND_TYPE = 1 for file logging. You have set 4, that is only for flight controllers with dataflash chips (i.e. Matek f405-wmn)
Yes, that was it, thanks a lot!
