I have a 5v bus whose voltage I want to log and be able to see in a log, since there might be aa power loss issue like brownout.
The pixhawk 2.4.8 has a analog port for airspeed which can handle upto 6.6v so I was wondering if i could connect the 5v bus to this pin and connect the common grounds and be able to see this voltage in the logs.
So, is this possible in ArduCopter and what software setup needs to be done?
Try setting up a 2nd Battery monitor for voltage only with the voltage pin set for 5 and connect it to the 6.6V ADC input. Not sure this will work but worth a try.
Or connect your 5vdc to a servo 5v pin where all the motor outputs are - provided none of the servo 5v pins are used for anything else. This should appear in logs under Powr.VServo
