Log Recorder and Log Analysis On Raspberry Pi
Hi All. I’ve been having problems in making a data recorder for drone on my raspberry pi.I’m making a flight recorder that starts recording the logs of a drone whenever it is armed and that logs can be stored in the sd card of the raspberry pi. I’ve tried several github repositories that can start logging the data of drone and a ulog file can be saved in my rpi. Now, I want to transfer that ulog file via bluetooth to my tab and i want an android software through which we can view ulog file. Do you suggest that I connect my rpi with Pixhawk and use a ulog file or another log analysis that can be viewed in an android tab or apk or also if for pc but through bluetooth of RPI? Which library should i go for log analysis and making a complete flight recorder on raspberry pi?
I am facing the same issue. Incase you find any solution, please do let me know.
Thanks
@aamadeuss kindly help him to solve this problem
