Log Browser Y bar color
Hi people! Could you change Y-bar value color from red to white please?
Very hard to see what is vibe level f.e. especcially outdor at suny day.
Thanks.
Put this in the Plugins directory of wherever your Mission Planner is installed.
LogGraphColors.zip (969 Bytes)
Edit the color palette as you see fit but this version is Red,White, Blue, …
Thanks, but why not to change red to white by default?
You’re asking for a custom release from sometimes overburdened developers. It’s not an unreasonable request, but perhaps others work in low light areas where white is more distracting than helpful. So, if you can “fix” it yourself, why not do so?
I don’t want that.
Thanks to Dave I can fix it myself now.
But you’r logic some strange for me- If white digits disturb at low light and deceided to use red digits on Y, why you use white at X- axis?
So I not ask about custom ver. I talk about global improove of Log Analizer to have it more useble.
Perhaps this scheme would look better in bright light?
I think yes. Especially if Y-values (vibe level in this case) will be black, not red.
I’ll play with color scheme some later.
Thanks to all.
P.S. strange that this disturb me only. I guess all drone-builders make tuning outdor and check logs outside also.
This plugin is much more friendly. Right click in the main graph screen and you will see some additions in the drop down menu!
LogGraphColors_SAFE_v1_8Q.zip (3.1 KB)
Make sure you replace the old one with this.
Dave, you’re great! Thanks!!!
