Log analysis Crashed!
Hey @rmackay9 , @Yuri_Rage , @amilcarlucas . I need help for analyses of UAV Log.
Hardware used - holybro 6c mini with unirc 7 and 5008 340kv motors. When i am analyzing logs i couldn’t able to find the root cause of the crash as vehicle stay at 85 meter last log reported at the height of 85m. their is no flag, no message which tells RC failure / disarming or anything not even the disarm button pressed but crashed happend as per client rc failsafe occur and it felt down. As per my experience with ardupilot i have see if any rc failsafe or disarming occur it saved in logs also.
Kindly look into the matter.
Thankyou.
I assume you simply lost power to the FC
but it might flag the radio failsafe disarmed
Your log shows an abrupt end without any indication; this happens when the flight controller suddenly loses power.
The log stops without any indication and has no valid date. But the log also shows that your power monitoring setup is not correct.
So either the FC lost power or lost first the SD card and than failed.
Concur. There’s not much to see here. There are a couple of RC and GCS failsafes sprinkled throughout, but they appear to recover without incident. And then the log ends.
There’s no need to continue tagging everyone you can think of when posting follow ups.
