List of automated ArduPilot flight log analysis software
Here is a list of free software tools that automate ArduPilot flight log .bin analysis:
This is free for now, but might change to paid at some point:
These are paid:
It’s probably better to improve one of these existing tools rather than build a new one from scratch
From my point of view, I will never ever contribute to any LLM- based (marketed as “AI”) tools for analysis, because that’s improper use of computing power and damage to the reputation of the term “artificial intelligence”. (Contributing explicitly that is; I am aware that each and every post containing log analysis, including my posts, is fed into the tools without any agreement from the authors, and they cannot do anything about that)
For possible tool development directions, I would expect that integrating (properly designed) analytical tools into configuration tools should be a good idea, which is probably underdeveloped at this moment. I would like to be part of that, but at this moment I struggle to find time for my existing projects…
I have yet to see an AI enabled tool produce a single credible log analysis, thus I am skeptical that any are worth pursuing.
Yeah LLMs are far away from any useful output today.
I think that’s too broad a statement, as mine may also be. The real issue appears to be that most of these projects flooding the community seem to have been generated by those with limited skillsets in both coding (leaning heavily on “vibe” coding) and foundational knowledge in robotics, flight, and specifically, ArduPilot and its associated logs. So it follows that their creations are equally limited.
I think they should be directed to the Discord Channel. Research, Experimental or create a new category. It’s much quieter here since the scrum of the run-up to the Gsoc selection…
That said I’ll be curious to see what Omkar Sarkar comes up with.
I am curious, do you have any insights into the project Omkar Sarkar has developed? I was considering a similar approach using a Hidden Markov Model BUT found my way better. @dkemxr
Hey @BeastAyyG , The HMM part(which is only a secondary part of my project) is mainly for identifying patterns and filtering transient/noisy behavior across time instead of acting as a classifier that will blindly outputs a root cause. My current idea is not to let the model directly analyze raw logs or make the actual diagnostic decisions.
The goal is more of a structured diagnostic engine with LLM explanation/orchestration on top, rather than replacing engineering(physics) analysis with an LLM.
I think we’ll be posting dedicated blogs for each project soon with more details. I’ll try to explain the full workflow in depth there.
Hey Omkar,
Thanks for the feedback. I was actually discouraged by some community members from adding an LLM layer because they felt it would just be a wrapper. However, it was already part of my original plan — to use it strictly for explanation and orchestration on top of the structured engine, not to replace the core analysis.
— BeastAyyG
fine i will do it my self
We have been using AYNA diagnostics tool and refining it based on learning on the field. It doesn’t use LLM during the diagnostics.
It include multiple checks from ardupilot community and feedback from users. However it is designed to provide context for ai agents to combine with other data points to surface issues.
Honestly I found the community feedback sometimes too opinionated. As an engineer I like facts and path forward and this tool attempts to do that.
@aero-oli I added yours to the list above.
Today two more tools poped up:
I already added them to the list in the first post.
Now, where is that Intern to try all these tool out…
I updated the list again today. @OmkarSarkar204 has finished his GSOC2026 project and AMC has now a robust, albeit not complete, analyzer.
I don’t know if this one fits here. It has an integrated AI assistant that can read both params, logs, user notes, and so on, allowing it to guide the user through the process of tuning or optimizing the drone’s settings.
It fits here yes.
But I would prefer if we could combine our efforts, and integrate your code into AMC
I’d like to have a light, mobile-based agentic app with the ability to tune/fix drones in the field.
Is it possible with AMC?
Yes, it is. If fact that is the entire purpose of the App. It is not a GCS!
Understood, thanks for clarifying! It sounds like AMC covers the robust analytical part perfectly. The reason I highlighted ‘mobile-based agentic’ is the workflow. ArduLoops is designed around an active AI loop: it doesn’t just parse a .BIN file statically, but uses an LLM to actively guide the user dynamically in the field, right from their phone. And it has integrated SITL, which can help beginners to understand how ArduPilot internal loops work.
If AMC’s architecture is moving towards supporting mobile platforms and active AI-driven feedback loops, I would be glad to discuss how we can merge our efforts. What would be the best way to combine AMC’s robust parameter analysis with an agentic LLM approach?
Hi All! https://logs.skybrush.io/ (webUI) is added to the list as “paid” but it is in fact free for a year, since its opening. We plan to introduce a credit system later on but it is not there yet so feel free to use it! It builds on our 15 years of drone swarming expertise and is basically an in-house tool that we developed for ourselves at https://skybrush.io to analyze drone show logs automatically for us and for our clients. As automated as can be, gathering useful info about a log out of the box with well defined test questions and deterministic output. We also added an agent friendly public API to it and an open-source CLI repo with a predefined AI skill with which it is very very simple to use it in your own agentic harness. See Skybrush Log Analyzer - Skybrush Log Analyzer (CLI). And a brand new thing is that during the APDC 2026 conference I started to integrate this CLI/API into the Methodic Configurator of @amilcarlucas, see the brand new branch at our fork: GitHub - skybrush-io/MethodicConfigurator at feat/add-skybrush-log-analyzer · GitHub . Any feedback is welcome, this tool is out for you guys to use, I hope it is helpful! And if you miss something, please send feedback, the feedback form is available on all surfaces/clients, even for your agent, so encourage them also to help making the tool even better! Thanks!
