I’m using a 2.5W VTX Rush Tank Solo in my drone. I recently started using the SmartAudio connection. I am able to change the frequency, channel, band parameters and power. Unfortunately, I noticed that Ardupilot limits the power to 1W.
After setting the VTX_POWER parameter to 2.5W, the VTX only reads 1W.
Is the VTX power limit to 1W a software bug or is it supposed to be like that?
I also have the same issue with AKK Ultra Long Range 2.5W on SmartAudio protocol, after setting 2500 mW to VTX_MAX_POWER osd vtx_power_level label starts blinking and real max power set with 1W instead of 2.5W.
Is there a solution for the unlocking vtx power? Any ideas to solve?
