bonjour,
j’ai un probleme
depuis 2 ,ans ,je mets regulierement a jour les firmware arducopter.
a partir de 4.5.6 et apres ,la liaison rc est perdue…je reviens à la version 4.5.5 et tout est OK
je ne trouve pas de reponse !!!
je peux rester avec cette version sans probleme mais j’aime pas rester sur un echec
merci beaucoup
firmware 4.5.5
elrs 3.5.1
FC diatone mamba F405 mk4 mini
[arducopter 4.5.5 3 01-01-1970 01-00-00.bin (165.5 KB)
num POST TUNE.param|attachment](upload://hr6WUveCpD6VoDAWgnGbUF0srqr.param) (19.6 KB)
Hello I have a problem For the past 2 years, I have been regularly updating the Arcopopter firmware. From 4.5.6 and after, the RC link is lost… I’m going back to version 4.5.5 and everything is OK I can’t find an answer!! I can stay with this version without problem but I don’t like to stay on a failure Thank you very much
From the hardware information:
SERIAL1 PPM / SBUS RC Input (SBUS pin MUST be used for RC input unless alt config used)
PPM->RX1 SBUS->TX1
Do you have the RC signal wire connected to Serial1 RX1 or TX1? In some diagrams it is labeled as PPM and SBUS.
You might just have to BRD_ALT_CONFIG,1 back to 0
I’am new to Ardupilot and I’ve the same issue. I’m using an elrs 886 receiver on UART2. I spent hours trying to make it work with the last stable version before to read this, back to 4.5.5 and everything works well at first attempt… So this is not an answer to your issue but a confirmation that there’s an issue in the software for this board, starting on 4.5.6 version. Thanks a lot for you’re input.
