Learning Ardupilot, starting with ESP32
yes I just mean its not a native usb port I was using those pins to verify my other usb serial adapter was working.
I can get mavlink working on 16 and 17 but not on 12 and 13.
I cannot get the GPS working on either port, should autodetect work?
the compass is not detected, its a QMC5883p
Hm, I use a Holybro M10 mini with no problem. But the Holybro M10 has a true ublox chip. In my case it is auto configured by the FC. The ESP32 firmware has no special features other than the normal Ardupilot firmware for GPS as far as I know.
But on the other hand I assume your HGLRC is working with your F405. Is it there auto.
configured?
Another case is the compass. The Holybro M10 min is using a IST8310 and this is specified by my HWDEF. So I hope it is possible to change this by a new specification of the HWDEF. Do you have the I2C address of your QMC5883p from your F405 setup?
Than I can try to modify the HWDEF tomorrow.
At the moment I have no idea why MAVLINK is working on one port but not on the other. In princip there is no difference between the ESP UARTs.
something might be wrong with my gps module im trying to find another one.
old ublox m8p is detected ok on port Serial 3 (16 17)
it is not detected on Serial 2 (12 13)
nothing at all from the other GPS I think its faulty that is probably why the compass is also not detected.
so long story short, Serial 2 doesnt work.
I checked SERIAL2 (12 13) succesful on my board with MAVLINK. For this test I used exact the binary send to you yesterday. The older firmware 3 weeks ago does not have SERIAL2. Are you sure that the last FW is flashed.
Its working now after reflashing it.
I am using my old Here+ v2 M8p Rover GPS receiver, as far as i can tell it has a Invensense ICM20948 compass.
The rgb status leds are flashing so i2c is connected ok.
I think you edited your last post :grinning_face:
If I understand know:
  1. SERIAL2 (12 13) is now functionell after reflash.
  2. GPS is working
  3. Compass maybe work, did you verifiy with mission planner if the correct compass is detected on the SETUP/HW_ID tab?
    Which IMU type you want to use as this is also hardcoded by the HWDEF?
if i could use the ICM20948 in the gps for imu and compass it would simplify the wiring significantly but im not sure having the imu on the gps is the best idea as the gps wont be as solid mounted as the flight controller.
Using a 9DOF chip makes sense. So let us try the ICM20948 first.
So again does mission planner Setup/HW_ID show any IDs on the setup from last night?
I try all the day now that the ESP-32 FC autodetect devices on I2C as other FC, but still no success. The reason might be the general AP-libaries as there are many "if"s based on FC type.
I dont think its being detected, the RGB status leds are flashing on the module so i2c is working.
You are right it is not detected, give me some time to check
Are you able to produce same picture with your M8p Rover GPS receiver connected to your normal FC (F405)?
I dont think its possible to use the imu on the gps
the compass is detected on my matek h743 as a AK09916
Thanks, but ok I missed that the normal FC has internal IMUs.
It is now a little try and error!
Please check following version: https://drive.google.com/file/d/1of3shxZ7K8aB6x4qJuk4Z6KFvYRbrhVz/view?usp=sharing
Compass is detected
MPU 6050 is no longer detected
Not quite the good news we had hoped for.
But you’re now saying that the MPU-6050 is no longer being detected. Was a MPU-6050 detected previously, and is the MPU-6050 connected to the ESP32?
yes it was working before. i have a little i2c splitter board attached.
its detected again once i flash it back to the last version.
Ok, this I didn’t know. Is it possible to remove the MPU6050 and try again the new FW. As far as I know the MPU6050 is using the same I2C base address as the ICM20948
it looks like its only detected as a compass
Here is a slightly modified version. Unfortunately, I cannot test this myself because I do not have the appropriate hardware.
https://drive.google.com/file/d/1OwLRZaVMRym-_MU-IEKgnuRxGDmNGa08/view?usp=drive_link
