Hello everyone,
I’m building a heavy-lift, 40", quadcopter based on ArduCopter. My current approach is to use a 7-inch test quad to configure the firmware with AMC (Methodic Configurator). Once I have a good baseline, I transfer the configuration to the larger aircraft and adjust the initial tuning parameters to better suit the heavier frame. Using this method, the large quad flies quite well.
However, I’m wondering if there’s a better or more standard approach for setting up and tuning a large heavy-lift quadcopter safely.
Would it be better to continue using my current workflow and then fine-tune the larger aircraft with AutoTune or QuickTune? Or is there a recommended process that experienced builders follow when moving to a much larger platform?
I’d appreciate any suggestions or advice from those with experience tuning heavy-lift ArduCopter builds.
Thanks!
