KakuteH7 ArduCopter 4.7.1 - repeated "CrashDump data detected", same fault in two dumps
Hi, my KakuteH7 keeps showing “PreArm: CrashDump data detected”, even after reflashing. Setup: - Board: Holybro Kakute H7 - Firmware: ArduCopter V4.7.1 (dbe79216), flashed with Mission Planner - Last log in use: /APM/LOGS/00000129.BIN History: - The quad was yawing left and right erratically in flight, then crashed (soft landing, one rotor touched). - Afterward the board got stuck in the bootloader (port showed KakuteH7-BL), then came back when connected to a PC. - I reflashed the firmware, but the crash dump warning came back and a new dump was created. Crash dump analysis (I attached both files): - Both dumps show the same fault: PC = 0xE000FFFE, r10 = 0xE000FFFF, LR = 0x08128791, SP = 0x3001A568. - The same call chain appears on the stack in both (0x08128791, 0x0813C161, 0x08128787, 0x08128675). - Dump 1 is 263,208 bytes and dump 2 is 263,360 bytes, so they are separate events. - UART3 showed framing and noise errors in dump 1 (FE=131, NE=154, RXDRP=2219). Could someone decode these against the 4.7.1 KakuteH7 build and tell me whether this is a firmware bug or something in my setup? Happy to provide the flight log, parameters, or test other firmware versions. Thanks!
Provide the flight log and parameters.
I have reinstalled the firmware from fresh after reinstaling my compass is not working properly and i checked my 5v power rail with my multimeter it shows only 4.86v on the flightcontrolller 5v pad and now it while flying it has a very bad wobbling and shows a warning of potential thrust loss motor 1 and motor 2.I don’t know if my flight controler has gone bad because there are so many errors now that i can’t even tell
1792498989838_crash_dump.bin (257.2 KB)
Here is the file for the crash dump
Now today it is smoking
