Been trying to get the Matek M8Q-CAN working with my Kakute F7 but no luck. The board is running the KakuteF7-bdshot target, and I’ve built the .apj on my local machine. This particular M8Q-CAN unit is running the newer Matek firmware that supports MSP.
I’ve wired TX3 (yellow) and RX3 (blue) on the M8Q-CAN to RX3 and TX3 on the Kakute, and it is being powered off the 5V BEC on the FC. My relevant params are as follows:
SERIAL3_PROTOCOL = 32
SERIAL3_BAUD = 115200
GPS_TYPE = 19
BARO_PROBE_EXT = 4096
COMPASS_TYPEMASK = 0
Arducopter is not detecting a compass or GPS at all. I’ve (hopefully) ruled out a UART issue, by connecting the M8Q to where I had a working TBS Crossfire receiver and still no luck. I’ve also tried a few different UARTs, and none of them work.
This particular unit has worked before with Copter 4.1.0 on a Mamba F405 board. Having a spare Pixhawk lying around, this unit also works OK with CANBUS. I’ve got another spare M8Q-CAN, and the other unit also does not work with the Kakute.
Wondering if this is still a configuration issue, or are there some build arguments that are needed for the Kakute to support GPS/compass over MSP?
Thanks,
Chen
