Kakute F7 AIO S.Port Telemetry
(Dimitris Arampatzis) #47
Yes I am
I have it already at my big coaxial X8
But at my big copter I use frsky X8R that has smart port in and I get each cell voltage from flvss
Can I connect the flvss some how to holybro and Frsky xsr?
(Dave) #48
I don’t use any sensor modules but yes it should work the same way as your X8R.
(Dimitris Arampatzis) #49
At my pixhawk I connect serial 4/5 too craft @ theory cable too flvss too X8R
So at Kakute I have too connect the uart tx5 too flvss too xsr??
(Jonathan) #50
How-to diagram about half way down the page below:-
http://ardupilot.org/copter/docs/common-frsky-telemetry.html
This diagram…
Although I’m using the new inversion code, so don’t need a special cable. Connected on T2
(Dave) #51
You could probably use T2 but it’s suggested to use T6. See here:
(Jonathan) #52
For reasons I haven’t yet had chance to diagnose T2 worked and T6 didn’t.
I mentioned just in case it wasn’t just me.
Once I’ve had chance to diagnose I’ll report back
(Dave) #53
Any available Tx port should work I would think. I’m using T6 with an inverted Sport input on an R9MM with the serial option set to 4.
(Jonathan) #54
Just reporting back, S.Port worked on T6 this time, not sure what caused previous issue, I can’t replicate it.
(Jonathan) #55
Not sure whether it’s just my setup, but I’m finding telemetry very unreliable, usually works to start with, then falls over after just a few minutes, even though connection to receiver still no problem. Once it drops it doesn’t return without a reboot.
Any suggestions?
9XR Pro, ersky9x, X4R-SB
(David J Gagnon) #56
I keep hearing folks refer to SERIAL4_OPTIONS or SERIAL6_OPTIONS. I don’t see these in Mission Planner full feature list. Am I missing something?
Like many, I am trying to get telemetry from a Kakute F7 working on an r9 mini and have tried using the TX4 to s.port. I set the protocol to 10 (frsky passthrough) and baud to 57 (which I read doesn’t matter). No new sensors are discovered on my X7. I’ve also tried TX6. This inverted/non-inverted mess was one of the reasons I went f7! Any help appreciated.
(Jonathan) #57
The new inversion code uses options. Option 7 is for s.port - (one wire inverted)
SERIAL4_BAUD 57
SERIAL4_OPTIONS 7
SERIAL4_PROTOCOL 10
(Anthony Short) #58
Protocol 10 is passthrough, which is used with the yaapu telemetry script or similar. I don’t get any new sensors discovered on the TX with this option either. Have you tried the script?
(Dave) #59
Install the latest (Master) version of Arducopter for the Serial Options parameters. Also update to the latest Mission planner and you will have a pop-up dialog menu with check boxes to configure the Options.
For example this is the config using the Inverted S.port input on a R9MM Rx. It’s Plane but Copter is the same.
(Dave) #60
I use Yaapu on every model. Copters, Planes and a Rover. It’s great.
(Ricardo Maroquio) #61
Hi, David.
Probably you will not gona make R9 mini work. I hope you do, but I tried a lot. The solution was buy a R9 MM receiver and use SERIAL4_OPTIONS=4 and SERIAL4_PROTOCOL=10 with Yaapu Script and master version of firmware.
Regards!
(Dave) #62
The mini might work but no-go with a Slim. Unless they fixed it with the latest firmware but like you I switched to the R9MM and all was good right away.
(Jeremiah Smith) #63
2019-02-13 190201 Fix the incorrect telemetry issue
It looks like there is an update for the R9 slim. I will test it tonight.
(Jeremiah Smith) #64
I can confirm that it works on an F405-wing with an R9-slim + and the latest firmware. I used the settings suggested by Dave.
SERIAL4_BAUD 57
SERIAL4_OPTIONS 4
SERIAL4_PROTOCOL 10
(Dave) #65
Working for me also with a Pixracer.
(oğuzhan) #66
hi all. i use omnibusf4v3 with latest arduplane daily builds. everythings work fine execpt frsky telemetry. i have r9m and r9 slim+ set. r9 slim+ has inverted s.port out. i connected tx1 to inverted s.port(receiver pin rx1).set serial1_protocol =10 and serial1_options=4. it only shows the gps sensor. no other sensor. i tried deleted all sensor an re-adding new sensor. but still same. only gps.
