Deafro
(Deafro)
July 20, 2018, 6:05pm
1
Following the guide to build a JSBSim through Arduplane listed here.
http://ardupilot.org/dev/docs/setting-up-sitl-on-linux.html
Followed the steps and inputted “sim_vehicle.py -f jsbsim:Rascal --console --map”
The simulation loads, but I receive the error “JSBSim: No such file or directory, Unable to start JSBSim”
I have the git repository on the computer, but I’m guessing it hasn’t been added to the $PATH? What should I do to fix this problem?
Deafro
(Deafro)
July 23, 2018, 1:39pm
2
Pulled the latest version of JSBSim and built the files, but still getting this error.
You need the latest ArduPilot version of JSBSim installed
and in your $PATH
I notice it says “the latest ArduPilot version of JSBSim” but is there a Ardupilot version of JSBSim? If so, how do I get it?
I also followed the instructions and i am getting the exact same error:
“You need the latest ArduPilot version of JSBSim installed
and in your $PATH…”
Does anybody know a solution to this problem? Any help would be highly appreciated!
SOLVED!
Obviously Ardupilot and Jsbsim have to be cloned to the home directory for Ardupilot to recognize Jsbsim.
I have the same problem, except that both jsbsim and ardupilot are cloned in my home directory. I have the following entries in my .bashrc file.
export PATH=$PATH:$HOME/jsbsim/src
export PATH=$PATH:$HOME/ardupilot/Tools/autotest
export PATH=/usr/lib/ccache:$PATH
I still get “JSBSim: No such file or directory
Is there anything else that could be going wrong?
Which version of JSBSim are you using?
The newer versions moved things around; the current Vagrant env does this:
export PATH=$PATH:$HOME/jsbsim/build/src
Hey! Sorry for the late reply.
You were right that got it working.
