I finally got around to doing a clean loiter batter life test on the Journey. I plan some more but the initial one came in just over 10:30 before RTL was triggered (the specific RTL behavior was not what I expected – I need to check to make sure that I set the correct RTL parameters to cover the failsafe cases). This comes in right as advertised. The current failsafe voltage cutoff is fairly conservative (3.46 I believe), so more time could be wrung out by setting it a bit lower if desired.
