Hi Rob,
I loaded Puneetpx’s 450 configure file and ran through the mandatory hardware setup again and everthing worked ok. In the basic tuning, I moved the roll pitch slider amost all the way over to get good swash plate movement and went outside and hovered it around a little. I am using H1 and Flybarless so Acro works, a possible bail out for me if somthing goes wrong. I understand flying in the flybarless mode with a flybar, I have two intagrators working independantly but It seemed ok. on this machine I can change the bell-hiller ratio to remove a percentage of it if needed. I did get it to wobble a little like the gain was a little high out of ground effect if I “bumped” the cyclic stick and made a quick move. I was expecting much worse, not bad for using 450 PID’s.
When I switch to alt hold, on the bench the swash drives down maybe 25% or so. not all the way to the bottom or top like before. Is this normal behavior?
Somebody needs to make a video of what is normal on the bench with a proper setup and what to expect when the flight modes are changed.
Progress is nice, on to the tuning process,
Thanks again,
BV
Thanks for for all of the help
