Hello, I am currently a new builder in drones. I am working on an autonomous drone with machine vision capabilities using OpenCV however I have problems communicating my Jetson TX1 with the Pixhawk flight controller. The connection is via USB.
I am just starting to test the motors with MAVLink protocol but I’m not quite getting the right outputs.
Here’s how the code basically looks like:
int main(int argc, char *argv[]){
cout << "Test 1 Started \n" << endl;
usleep(500000);
Command_Stabilize();
usleep(1000000);
Command_Heartbeat();
Command_Arm();
usleep(1000000);
Command_Throttle(1100);
cout << "Throttle increased \n" << endl;
usleep(2000000);
Command_Throttle(0);
cout << "Throttle stopped \n" << endl;
usleep(2000000);
Command_Disarm();
cout << "Operation stopped. \n" << endl;
return 0;
Please bare with me here because I have no previous experience with drones or MAVLink protocol. Basically the test starts off with stabilizing the drone then arming, starting the motors for 2 seconds, turning them off then disarming.
The Pixhawk gave off a beep to indicate that the arming and disarming was successful however the motors do not move at all when increasing the throttle.
Here’s the function:
void Command_Throttle(int throttle){
mavlink_message_t msg;
uint8_t buf[MAVLINK_MAX_PACKET_LEN];
mavlink_msg_rc_channels_override_pack( system_id,
component_id,
&msg,
target_system,
target_component,
UINT16_MAX,
UINT16_MAX,
throttle,
0, 0, 0, 0, 0);
uint16_t len = mavlink_msg_to_send_buffer(buf, &msg);
int serial = -1;
int written = 0;
serial = OpenSerialPort();
if(serial != -1){
written = write(serial, buf, len);
if(written < 0){
cout << "Failed tp wrote to port \n" << endl;
else{
cout << "Adjusting Throttle" << endl;
It successfully output to indicate that the serial was written.
Any thoughts about this? Other than MAVLink is there a better way to communicate TX1 with Pixhawk?
