Issue in Holybro Kakute F722
I recently bought kakute f722 flight controller (Kakute F722 Flight Controller – Holybro Store) and wanted to flash arducopter in it but wasn’t able to do so because when I try to upload the bl_heli firmware after doing the necessary steps it shows some error in beta flight configurator. Even on configurator it showing board name as kakutef7miniv3. So I wanted to know if this board is compatible for ardupilot or not?
Else if someone knows how can I flash the ardupilot firmware in it then please help…
It is not. No F722 based FC is
But, Holybro says it is. But this is for the F745 board.
From their own spec page:
Firmware Targets
  • Betaflight Target: KAKUTEF7MINIV3
  • INAV Target: KAKUTEF7MINIV3
  • Ardupilot Target: KakuteF7
What? I’m unable to understand you mean F722 is ardupilot compatible and F7 is not? or the opposite of it
F745 is compatible, F722 in not. What you have IS NOT.
Type F722 into the search box here on the forum to see others like you that bought the wrong Flight Controller to run Ardupilot.
okay thank you very much
I bought this FC for around $60 and is still applicable for exchange. If you could suggest me some other FC in which I can flash ardupilot and can use in this range…
I would suggest an H7 based board from Matek or Holybro (Kakute). TBS Lucid H7 is ~65.
