Is pixhawk 2.4.8 suitable for designing a 60 kg drone??? If not then why?? And kindly suggest me alternatives…
Thanks in advance
Thanks in advance
If you’re going to spend the time and money on a 60kg drone then I’m going to say no.
Will it work, maybe. But you can also get a Ferrari down the road towing it with a donkey.
If you’re going to spend the money for motors and ESCs and frame for a 60kg drone spend a bit more on the flight controller that will make your life much easier. Something with an H7 processor for example so you can run the tuning scripts needed for such a drone.
Read this post: Hardware To Avoid When Building Your First Multirotor
I love this analogy!
Thanks for the quick response…
As i have limited knowledge in this…
What are the things will be compromised if i use pixhawk 2.4.8?? If you can suggest…
Thanks in advance
The firmware is out of date.
Most of the 2.4.8 Pixhawk controllers on the market are clones with junk parts.
If you’re building a 60kg drone you are going to want to use features like QuickTune script and that can’t be run on the 2.4.8.
Look for a controller with an H7 processor. If you’re going to spend the money on such a big drone consider Cube Orange or one of the Pixhawk 6.
