is it possible to integrate Mobile phone GNSS receiver (INSTEAD OF USING GPS) into Flight controller?
Is it possible to integrate Mobile phone GNSS receiver (INSTEAD OF USING GPS) into Flight controller
Yes, ANDRUAV can let you use a phone’s GPS receiver for a vehicle, but I wouldn’t recommend using it as a primary GPS.
https://cloud.ardupilot.org/andruav-index.html
I agree,…wouldn’t recommend it.
There are various reasons:
- Update speed of GPS unit → In aircraft it is rather important to have a fast updating GPS receiver as aircraft can cover a large area / distance in a short time.
- Signal quality linked to a good antenna → There is a good reason regular GPS units have a certain size in order to receive a strong signal. (GPS signal is very low in signal strength → easy to miss or being affected by interference)
- Positioning during usage → An aircraft can fly at steep angles and in rotor aircraft also suddenly change direction. This can easily lead to signal loss - hence previous remark is valid for this point as well. (Whilst in a smartphone the assumption is that phone is facing up during regular usage)
