Is it possible to change waypoint speed and camera mount pitch?
I need to change waypoint speed and camera mount pitch during a mission. The simplest way seems to be a LUA script. Do the necessary bindings exist or is it possible to send a mavlink command?
Thank you,
Tobias
You can do the waypoint speed by changing the param from the lua script.
Mount pitch is a little harder, you could add a binding to do that. If its servo controller you can change the servo output from the script.
Thank you very much!
I use a Basecam setup as descriped here:
https://ardupilot.org/copter/docs/common-simplebgc-gimbal.html
I guess it is not possible to control without adding bindings (I do not know yet how to do that)?
But I think you guided me to the right approach.
I will try to modify a mission after it was loaded and add the waypoint speed and do mount control items. I think that should work.
You will need new bindings for the gimbal over serial.
Why not just change the WPNAV_SPEED param? Much easier script.
Yes, you are right.
This would mean I need to add a pull request for the new bindings? I think that is beyond my current knowledge.
I guess the method is this one:
void set_angle_targets(uint8_t instance, float roll, float tilt, float pan);
in line 121 in /libraries/AP_Mount/AP_Mount.h
Then I open a new section in /AP_Scripting/generator/description/bindings.desc
include AP_Mount/AP_Mount.h
singleton AP_Mount method set_angle_targets boolean uint8_t instance, float -90 90 , float -90 90, float -180 180
Even if that is right, the next step is beyond my unterstanding.
Open a command line prompt and cd to the /libraries/AP_Scripting/generator directory and type “make run”
Since that is a method which is interesting for many people it might be useful to implement it?
Yes, A PR would be great, you can always open a draft and ask for advice
Your binding is nearly correct, not much point in using the version with a instance as AP_MOUNT_MAX_INSTANCES is 1. This builds on master (but I have not tested in any way):
singleton AP_Mount alias mount
singleton AP_Mount method set_angle_targets void float -90 90 float -90 90 float -180 180
You should then be able to use in lua with:
mount:set_angle_targets(roll, pitch, yaw)
No need to manually run the generator anymore, it is run automatically when you build the main code.
Thank you very much! I have tried to make a pull request. First time ever. I hope that is right.
