Hi guys!!! I was flying with my drone the other day and I lost control of it. It started drifting sideways and going down and the controls became irresponsive. When I checked the apm the red light was blinking as if it had lost radio bind.
I tried flying it low again and as soon as I took off it triggered failsafe.
Here was the first Error for it. Does anyone know what this means?
Log File C:\Users\renat\OneDrive\Documents\Mission Planner\logs\QUADROTOR\1\2018-04-15 13-52-48.log
Size (kb) 195.06640625
No of lines 2912
Duration 0:01:03
Vehicletype ArduCopter
Firmware Version V3.2.1
Firmware Hash 36b405fb
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Brownout = GOOD -
Test: Compass = GOOD - No MAG data, unable to test mag_field interference
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: FS_THR
Test: GPS = GOOD -
Test: IMU Mismatch = UNKNOWN - No IMU log data
Test: Motor Balance = UNKNOWN -
Test: NaNs = GOOD -
Test: OpticalFlow = FAIL - ‘FLOW_FXSCALER’ not found
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = FAIL - Roll (-152.71, line 1982) > maximum lean angle (45.00)
Test: Thrust = GOOD -
Test: VCC = FAIL - VCC below minimum of 4.6v (4.505v)
As the report says you had a FS:Throttle event, in other words you lost radio.
As you don’t have your voltage and current configured, and the loging is at a bare minimum, that is about all that I can glean from the logs.
Here you can see the event against RCin.
The TH9X is a half decent radio, but I don’t trust the stock TX module or receiver. One of the things I don’t like about the stock TX and RX is that even though Fail Safe is listed in one of the Setup/Menu options in the radio, the stock RX does not have any fail safe functionality. BTDT…
The only way I know of to get a working fail safe is to upgrade to a FrSky XJT TX module and a compatible receiver like an X8R, X6R, etc.
This, coupled with the fact that the TH9X does not support flexible switch/knob channel assignments is why I bought a Taranis.
With that said, you need to make sure the receiver antenna is not being blocked or shaded by any carbon fiber and do a range check before each flight…
