I have an Iris and would like to use the provided transmitter with my other Aircraft and Helis. I DL the manual from FlySky but the programming is not the same.
The IRIS Transmitter does not have the System & Settings Menus. I cannot find where you change the Aircraft Type (Heli, Acro and Glider) I can access the model memory but that is it.
How do you BIND a Receiver??
If you have a Transmitter Manual please upload it. No programming information is provided with the IRIS.
I can use the stock parameters for the IRIS transmitter as well. I think I pushed a wrong button & now it wont even arm. Can someone please post 1-11 on their transmitter?
