IRIS -Circle mode NOT working - Please advise
Please help me…
Circle mode does NOT work…I’m not sure where to look…
I would imensely appreciate if you look at the last 3 logs…I dont know… maybe you see what is going on…:
dropbox.com/sh/jn4u0kj7rh9e … 89meSryHya
I downloaded all the files from SD on to Drop Box…
I updated the firmware as per manual and Youtube instructions…calibrated radio, chose IRIS parameters with GoPro in front
( I have a gimball front mounted…you can see in the photos).
Circle radius set to 400 cm ( I have a small park near by …4m…seems to fit…).
I dont know what I’m missing…
In spring worked beatiful…( I had 500cm radius …if that’s makes a difference I will try 5m over the weekend…)…now…after firmware updated…not working anymore.
RTL woorks., 10 sat on GPS count…
Updated:…I tried 4m, 5m , 6m ,10, and even 20m…Still nor Circle…
Again I appreicate any help.
Cheers
Have you performed the compass calibration?
What about the offsets, for some reason I can’t get the log :frowning:
