IR lock with ardu copter
I want to have precision landing using IR lock as I’m building a drone battery swap station, I haven’t used IR lock before,
I wanted to know, does the yaw of the drone behaves like it does using arcuo tags, I need the drone to always face a specific direction when landing, how can I do that using IR lock precision landing, I can’t use a Visual marker based landing as it will not work in fog,
which ranger finder should I use with it, I want a cheap option for starting, like 15m-20m is pretty good enough for me
and does F405 processors support IR lock Precision landing?
Hey, I want to do more or less the same. Want to collab? I am pretty good at coding, but I cant decide what route to take, either ground based tracking of the drone or the drone locking on a target. I would like to throw a few Ideas back and forth, if you are interested send me a DM
