Intermittent GPS Dropouts with simpleRTK3B Compass on ArduPilot
Hi all,
I’m integrating the simpleRTK3B Compass into my BlueBoat platform and encountering intermittent GPS dropouts in ArduPilot, despite stable readings in other tools.
Setup
Hardware:
Software:
  • ArduRover
  • Ground station: QGroundControl
  • GPS status cross-verified using UPrecise tool
ArduPilot Parameters Set
Based on the official ArduSimple guide:
  • COMPASS_ENABLE = 0
  • COMPASS_USE = 0
  • COMPASS_USE2 = 0
  • COMPASS_USE3 = 0
  • EK3_MAG_CAL = 5
  • EK3_SRC1_YAW = 2
  • GPS_AUTO_CONFIG = 0
  • GPS_AUTO_SWITCH = 0
  • GPS_RATE_MS = 100
  • GPS_TYPE = 5
  • SERIAL1_BAUD = 115
  • SERIAL1_PROTOCOL = 5
Issue Observed
  • Using UPrecise, the GPS position and heading update continuously and correctly.
  • But in QGroundControl, ArduPilot intermittently reports:
    • GPS Count = 28, 3D Fix
    • Then drops to GPS Count = 0, No Fix for ~9 seconds or more
    • Then recovers again, and repeats this cycle
Has anyone successfully configured a simpleRTK3B Compass with ArduPilot?
Any help or shared experiences would be greatly appreciated!
Best regards,
Yan-Liang Chen
I don’t think ArduSimple provides very good instructions on their site. I’ve used UM982 based hardware very successfully, though not the one from ArduSimple.
The ArduPilot GPS driver supports UM982 configuration. Set:
  • GPS_AUTO_CONFIG,1
  • GPS_RATE_MS,200
Then follow the instructions here for “Common Parameter Setup” and those marked for UM982:
Hello.
I used UM982 and didn’t experience any problems.
However, in my previous experiences, I encountered the same problem because the GPS was not at the correct Hz.
GPS1_TYPE = 25 (for UM982)
GPS_RATE_MS=200 (Default)
It should work when you do this.
I don’t understand why GPS AUTO CONFIG is turned off.
Hi @Yuri_Rage,
Thank you for your advice.
I’m using ArduRover, and the firmware version might be slightly different from the one in the example. Based on the instructions, I’ve set GPS_TYPE to NMEA, and configured the GPS receiver to send GNGGA, GNRMC, and GPHDT to COM3 at either 10Hz (0.1) or 5Hz (0.2) by adjusting GPS_RATE_MS accordingly.
Unfortunately, the issue persists. The GPS signal still drops intermittently. When a fix is received, it shows good values (24–28 satellites, HDOP ~0.5, 3D fix), but the signal can drop out completely for over a minute, making it unusable for stable operation.
I’m attaching a log file in case it helps with diagnosing the issue. Any further suggestions or insights would be greatly appreciated!
GPS_log.log (91.4 KB)
Hi @idris,
Following up on my reply to @Yuri_Rage — I’ve set GPS_RATE_MS to 200, and on the GPS receiver side I configured:
GNGGA COM3 0.2
GNRMC COM3 0.2
GPHDT COM3 0.2
Unfortunately, the issue still persists.
Additionally, after enabling GPS_AUTO_CONFIG, ArduPilot stopped receiving GPS entirely, and continuously shows “EKF waiting for GPS config data.” I’ve since disabled GPS_AUTO_CONFIG to restore signal input.
What is GPS1_TYPE?
Can you share a log?
